Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Ok, So far.. over this last month I have determine dthat it is a 1975 model.
I've fixed leaks in the power steering ( twice ) /forums/images/graemlins/smirk.gif And have found that when you fix a system with multiple leaks.. the leak just moves on down the line /forums/images/graemlins/smirk.gif
Got the electrical mostly straightened out. Had lots of fuses to replace.. got the oil and charge lamp working.. tach works ok. genny works ok.. Lucas regulator is a POS.. but I have fiddled with it enough to make it work.
Got headlamps rewired,a s well as r&r the rear worklamp, and ran new wire to it.
i managed to salvage the OEM 'allied signal' blinker aray that cam on the tractor. neat looking job.. lootks like a big dual lensed lamp, on a stubby perch the size of your balled fist.. setting atop the fender. There is a toggle switch on it to turn it on, and inside, there is a blinker element.
The element and switch were toast.. but i found 'will fit' replacements. Metal was pitted.. but i wire wheeled it down and filled the bad pits with jb weld.. then sanded and primed. looks 90% or better. Got new lenses, and had to make a gasket.
That fender.. the left one was the 'bad' one. Right fender just has surface rust.. no pitts, no extra holes, and no dents.
left fender had a couple / threed dents. 1 crack, and 1 small rust thru. Took about 8 hours work on and off.. but i got the dents pounded out, fliied, and sanded, and then got the fender primed on the side I sanded it. I still need to work on the back side and get it sanded.. but was concerned about the abre metal on the front.
Changed the oil yesterday.. previous owner had stronger hands than me.. I about never got the oil filter off.. Thought I was gonna have to do the screwdriver trick.
I've had the dash cowling off about 4 time trying to get it to fit correctly.... finally made it fit and look good.
Went and got a new stack for it as well. i couldn't stand looking at the floppy swept back one any longer. It was actually too big of a stack.. pipe diamater was way large.. and the prev owner just bent it down to 'kinda' fit.
Got a new grill and decals setting on the shelf for when i get some paint on the sucker.
Soundguy
Soundguy
