Culverts (again but for a paved drive).
   / Culverts (again but for a paved drive). #1
sanmigmike
Bronze Member
S.E. of Portland OR
Kubota L3830 HST
I've looked at some of the threads on culverts and have some idea of what to do but...?
My "bad" neighbor (long story but it has changed for the better due to his ill wife) is getting his part of a shared road paved. But there is less that 200 feet of road that he doesn't use that he doesn't need paved. However, much to my delight and pleasure, he offered to go ahead and pave it and split the cost of that portion three ways, one third for him and then a third each for us and our other neighbor. (I think his wife being ill and urging him to mend his ways was a big part of it and me rescuing his tractor helped change him from being a "bad" neighbor.)
This portion goes through a nice wooded area that has a few low spots and a slope. During the wet season part of the road gets wet and at times flooded. Two areas are the worst and one is about 18 inches lower than the road on the high side, the area that the water flows from. He and I think it would be a good idea to put a culvert or some other way of draining that before it is paved. Not sure how much space we need under 2 inches of asphalt. Most of the threads I have found deal with putting it in a gravel drive so? Ideas? Suggestions?
   / Culverts (again but for a paved drive). #2
I'd do a culvert under asphalt as if it were under gravel. Asphalt has no real strength. It only really acts as a binder to keep things from shifting.
   / Culverts (again but for a paved drive). #3
Whatever size culvert you put in, place that same ammount of gravel over it for cover. 8" culvert should have at a MINIMUM 8" of gravel, 12" culvert 12" etc...
Make sure you bed it in crushed gravel and compact it in lifts as you go. Nothing worse than paving a road over a poorly bedded culvert and having the pavement give out early.
Good luck.
   / Culverts (again but for a paved drive). #4
Same what "atgreene" said make sure you compact it really good as you go I would dig down a couple feet at least then start putting crushed gravel in at 2" incruments and compact then insert culvert where you want it and continue with the crushed gravel the same way. It is definately worth renting a vibrating compactor for this. If it is not done the correct way it will settle and you will be mad everytime you drive over it. My town highway department did one down the road from me. They dug up the road and put new culverts in and waited about a month before they actually paved it, but never compacted it properly and it settled about 4 inches over a couple months. After a couple months they came and patched it and now the road looks like crap becuase of the patch jobs.
Good luck whatever you do. It is definately nicer to have a paved road when winter comes around.
   / Culverts (again but for a paved drive). #5
OK, it depends on the type of culvert used. I agree with the previous posts about 2 inches of asphalt having negligible strength characteristics. However the burial depth of the pipe depends on more than the size of the pipe. ADS the manufacturer of the corrugated black plastic pipe with a smooth interior wall requires a minimum of 12" of cover. This pipe is as durable as the metal if bedded properly but will crush if you look at it wrong if bedded improperly. The smooth interior wall makes it a lot easier to maintain especially for small diameter pipes. The metal pipe may require less bedding depending on the pipe wall thickness. One other thing when using any plastic pipe that will have asphalt placed over it you need the twelve inches of bedding cover to reduce the heat. Good luck with your project.
   / Culverts (again but for a paved drive). #6
Hillfarmer is right about the smooth bore, forgot to mention that in my post. A smooth bore will flow 25-35% more water than a likesized metal corugated.
As for heat, I doubt that will be an issue, but the deeper the better. Compaction in good gravel with a slight pitch is the key. As well as good catch basins on each end to prevent silt from entering the pipe.
Good luck.
   / Culverts (again but for a paved drive). #7
Two types of culverts. Metal, which rusts, and plastic, which has a smooth bore and ridges on the exterior for strenght. With my own money, I will only buy plastic.
First you need to decide how big of a pipe that you need. 12 inches would be the minimum. You can buy smaller, but they just plug up and cause allot of headaches. If it's just a few acres that you are draining, or then 12 inch is fine. 15 inch will handle well over twice as much water. If you can afford the extra $40, buy the 15 inch as it will handle most situations. 18inch and 24 inch are just huge and are more for highways and massive runoffs that will require rip rap and cement to protect the road too.
Rule of thump is to have half as much material on top of the pipe as it's diameter. A 12 inch culvert needs 6 inches of material above it. I wouldn't count blacktop pavement in this equation, but either good quality clay or road base type gravel. Don't use one size or rock, it must be a road base type of materail with a large variety of sizes to the stones. They sould have jagged edges and should include allot of fines in the mix.
Before paving, it's very, very ,very important to get propper compaction. Your car, truck or tractor will never achieve this. You need a roller if you will be paving anytime soon. A vibratory roller is even better. This needs to be done along the full length of the road that will be paved, and any low areas that you create need to be filled and built up, then compacted again before spenind the money of blacktop.
If blacktop moves or settles after it's installed, it will fail. Once it starts failing, it just gets worse. If you have good compaction, a residential driveway will easily last a decade witout any major issues.
Two inches is fine for auto traffic. If you are driving anything heavy on it, then you need four inches. Heavy would be a vehicle over 10,000 pounds. Most RV's are way over this amount, as are commercial vehicles and delivery trucks.
Nice to hear you worked things out with your neighbor.
Eddie
   / Culverts (again but for a paved drive). #8
rusts? not much.. as it's galvanized!.. maybee onthe cut edges or miter joints. but those can be dressed.. OR.. for extra protection. get asphalt coated metal pipes..
The GC I work for has put in alot of culvert pipes in the 24ys we have been in business.. never had to go repalce one due to rust. We've also ripepd out alot and repalced when doing new roads and driveways. I've yet to have pulled a culvert out that was younger than 20 years that had anything more than nuisance rust on it...
Plastic ont he other hand... well.. i expect that stuff to degrade onthe edges where exposed to uv light, and eventually recede.. causing dirt to fall intot he swale and choke the flow down.. over time of course..e tc. I'm also not a fan of hardi pipe for anything other than deep comercial projects where taxpayer money is an issue.
concrete drainage pipe, and where available, terra cotta drain pipes are also long term, durable possibilities.
On second thought..if I used the black plastic.. I think I would find it acceptable if i also used a concrete spillway and concreted inthe mitered end section so that no poly was exposed to the sun.. etc..
soundguy
   / Culverts (again but for a paved drive). #9
OK my driveway has everything mentioned not to do here done to it and I dont want to even talk about how much gravel is over it. Thank god my culvert pipe cannot read this thread it would fail on me immediately if it knew how badly it is installed
   / Culverts (again but for a paved drive). #10
Soundguy, I think you are talking about polyvinyl chloride (PVC) plastic and not high density polyethylene (HDPE). The HDPE does not have the same UV degredation potential as the PVC. Plus if you paint PVC it helps with the degredation problem. Mowers are a bigger concern for the end of plastic pipes, but better the pipe than the mower.
Ford Pickup NR (A50323)
Ford Pickup NR...
WOOD GRABBER FOR MINI EXCAVATOR (A53843)
WOOD GRABBER FOR...
JOHN DEERE 6615 TRACTOR (A51406)
JOHN DEERE 6615...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2006 KOMATSU WA200-5 WHEEL LOADER (A52705)
2006 KOMATSU...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
