beowulf
Veteran Member
- Joined
- Dec 31, 2003
- Messages
- 1,177
- Location
- Central California Foothills
- Tractor
- Kubota L3410 HST, J Deere riding mower
A very small- but useful- pond here has an earthen dam. The overflow culvert is a 20' long, 12" dia. corrugated plastic culvert (like abs sort of). The pond-side end of the culvert is about 2 - 3 feet down from the top of the earthen dam and the culvert slopes down to a creek on the other side of the dam at a rather steep angle - guessing about 20 degrees or so. Also, it is not perpendicular to the dam but angles off at about 30 degrees. I have no idea why it was put in that way.
This means that the overflow does not directly go into the creek but flows off to one side of the creek and that causes a roadway there to be very narrow. If the culvert went straight across the dam it would be much better for the reasons I outline here. The second problem is that I want to widen the dam (dump more dirt/rock on the creek side) but cannot do so as it would cover the down-side culvert opening - so I want to extend the total run of the culvert.
So what I propose to do is to use a 10' 15" dia. section of the same kind of culvert (which I already have here) and cut one end at about a 20-25 degree angle and slip it over the down-side end of the 12" dia culvert (I know/hope it will just barely begin to slip over the 12" culvert which is likely near 15" for the outside dia.) and to use a plastic wrap around the "joint" and then to build a form which will allow me to pour concrete all around that joint. I also thought about slipping the 15" dia culvert over the 12" end and then about 3 feet down line from there to cut out a pie shaped section and turning it there, wrapping it and putting the concrete there as well. If this works out the end of the extended culvert will be right into the creek and will be sufficiently farther down so allow me to widen the dam on the creek-side.
I wanted to simply get another section of 12" dia. culvert and attach it with an "angled" coupling but I cannot find an angled coupling - don't think they make them.
I think I can make this work, but also think that someone out there may have a better idea, or have suggestions as to how best do it the way I am planning. I will also be adding another overflow culvert at the other end of the dam as the water flowing into this pond can be substantial in heavy rains and when the pond is already full I have had issues with the existing culvert handling the flow.
Digging out and realigning the old culvert is not an option.
