Cultivators
   / Cultivators #1
threeman
I asked this on attachments but didnt get a response. What are you using for cultivators for your crop or garden? I am looking around for another set.
Pictures would be great. Also thinking of trying to plant with the 9540 this year, possibly.
   / Cultivators #2
What's a 9540? Pictures would be great. BobG in VA
   / Cultivators #3
Back when I was still putting out a corn crop every year, I'd use a John Deere RG430 (rolling gaurd, 4-row X 30") 3-point mounted cultivator. Now that all I'm doing is a 1/4-acre of sweet corn and roughly a 1/2-acre of popcorn, I just run through it with a rear tine walk-behind tiller. (and a hoe)
The rest of the garden is all done with the same tiller.
I use one of 3 2-row planters to plant the corn and a big patch of green beans.
   / Cultivators #4
For the veg garden I use a 1974 Bolens G1453 garden tractor with a 32" pto-driven rototiller. Found this one on craigslist last year for $600. It came with a 42" mower deck also.
For my small 6-acre hayfield I'm fixing up a 13" wide tandem wheel disc, also $600.
   / Cultivators
kubota 9540 is a tractor.
We usually plant with 3000 ford, I sold my 3910 like a dumb ?$$. Anyway been looking around for another set of planters. We have a set of cole 2 row planters now and KMC rolling cultivators 4row. They work well but are getting pretty worn and need some TLC. They belong to my uncle so I bet it doesnt get done. I kinda like the looks of the 71 planters but I am still wondering about the 7000 series planters. I havent seen them up close.
Back to the cultivators, the KMC's work wonders and also if you need a bed to plant by hand they work well for that too. Keep them coming.
   / Cultivators #7
Interesting.
So are we talking row crop cultivators or field cultivators? I can't tell from what I see on the KMC website which one of their products is your "rolling cultivator".
   / Cultivators
row crop. man the KMC's we have are old. I know where an 6 or 8 row set is I have been trying to buy. If I do I am going to convert them to 4 row.
I am sure KMC doesnt make this model any more.
Check that they do make a similar model if its not the same. 4 row speed wheel cultivator.
   / Cultivators #9
Most years I put in up to 10 acres of field corn in 36" rows (for deer to make hunting easier) all planted in small 1/2-2 acre patches, and 2 acres of sweetcorn (for my family, friends , and neighbors consumption). I dont use any herbicides, and use a Farmall Cub with mounted cultivators. In my opinion, this is the finest piece of one-row cultivating equipment that can be found for gardens or smaller acreages. Generally, a one row cultivator will do a higher quality job than multiple row setups because every row gets a double pass. The offset "cultivision" lets you look right at the plants without neck-strain so you can get on them quicker than you could with just toolbar cultivators on the rear. You can also set the cultivators to get in closer to the plants which is important without herbicide use. Fuel economy from that tiny 4 cyl gas engine is exceptional. Back when I had more corn acreage and larger blocks, I used a Allis Chalmers C trike with mounted cultivators. You could not get as close with that one, nor get on the crop as early, but it nocked out the work a lot faster at higher speed and with a two-row setup and had slightly better crop clearance than the Cub. The trike is nice for turning on a dime at the end of the rows, much tighter than possible with a wide front even if it has good brakes. You can easily work you way across a field continuously without allowing a few rows for turning like needed with a wide front. Unfortunately, trikes are too risky to manufacture today with all the laywers and folks looking for a "free ride". They are easy to lay over on hills, ditches, or if you encounter a woodchuck home with a rear tire and take a good deal of caution and know-how to operate safely.
   / Cultivators
i know what you mean about neck strain for sure. I also know about the cub and cultivator setup. It sure was easy just keep an eye down and you are set. My grandpa liked the cubs he had two. Sure would like to have one of them now, just because they were his. He did everything with his and planted probably 4 acres or so of garden each year. Yes I have alot of uncles and aunts, then he also fed the neighbors.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
2013 WABASH 53x102 DRY VAN (A53426)
2013 WABASH 53x102...
1992 International F-4900 Grapple Truck (A51692)
1992 International...
Hydraulic Coupler 80 mm Pins (A52384)
Hydraulic Coupler...
