Tiller Cultivator Shank Adjustment
   / Cultivator Shank Adjustment #1
Wayne_Freeman
Beaufort, SC
Kubota L3400
This is my third year using the Agri Supply Kelvinator 3 PT KEULAVATOR FRAME - Agri Supply in our garden . The problem I am having is one of my cultivator shanks continously kicks up. CULTIVATOR SHANK TO FIT INTERNATIONAL - Agri Supply The spring has a nut on top where you can increase the tension that I assume increases the kickback load? I have the spring almost totally compressed by tightening the screw but yet the kickback occurs constantly? The same shank on the other side works great and is not nearly as tight. I am not sure at this point how to try and resolve this? Any help is reatly appreciated!
   / Cultivator Shank Adjustment #2
Agri supply sells some good but cheap quality stuff. I would contact them and tell them that you have a proble since the beginning and you have adjusted over the years but its not right. I think you have figured it out. I think maybe your bad side has a bum spring. since the other side works fine.
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
2016 Chevrolet Traverse LS SUV (A50860)
2016 Chevrolet...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
