Cultipacker wheels
   / Cultipacker wheels #1
logankelly
Bronze Member
winona mn
jd2520
I see here that a lot of builders use end bearings/pill blocks for the end shafts that the Cultipacker wheels are on and most of the Cultipacker wheels are meant to roll on a stationary shaft. Example is the wheels you get at Agri supply are designed to spin on a 1 3/4 shaft so the shaft does not have to be on bearings.
Am I missing something?? because I am going to build a 5.5 foot one using the agri supply wheels
   / Cultipacker wheels #2
The shaft spins to reduce the wear. It also helps when turning. Good luck with the project!!:)
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
159118 (A60430)
159118 (A60430)
2020 FREIGHTLINER CASCADIA SLEEPER TRUCK (A59905)
2020 FREIGHTLINER...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
