Culligan and Septic
   / Culligan and Septic #1
fenneran
Staunton, VA
Kubota L2900
Hello all,
I know water softners were discussed a couple of weeks ago, and the general consensus was that the waste should not be plumbed into the septic line. We just contracted on getting the system installed and they are coming out next week to put it in. The guy who came out to set up the install (manager of the local franchise) said that they now plumb them into the septic systems. I was shocked (and told him so) because I had always heard that this was a very big no-no because it ruined the septic. He said that used to be the conventional wisdom, but studies had shown that it actually helps the septics by stirring it up when it flushes and the minerals (salt) does not hurt the system at all. I am very skeptical and thought I would check with the brain-trust here to see what you all thought. Again, I know what the conventional wisdom here is, but do any of you actually know what the deal is with this? Do any of you have yours plumbed into the septic (or know of anyone who does) and what the outcome is? Anything you can get me will be good. If I have to postpone the install until I can get comfortable with the plan, so be it.
Thanks in advance. /forums/images/graemlins/confused.gif
   / Culligan and Septic #2
fenneran, All my friends here in the Texas hill country have them plumbed into the septic system. I have heard of no problems. I would believe the Culligan guy, water is their business.
   / Culligan and Septic #3
My system was done by my well builder and he has ALL of the backflushing of ALL of the filters going into my SUMP PUMP basin.
NOTHING goes into my septic. Have you ever seen what salt does to concrete. It oxidizes and peels the concrete and weakens it. Now this won't happen overnight or maybe even in 5 years. But it isn't good for it long term.
Do you have a sump pump basin he could run the backflush line to? Or does that go into the septic also?
   / Culligan and Septic #4
One second thought, I wasn't thinking of in the first reply, they are fairly easy to install. You might save a lot of money buying one from LOWES or Home Depot and installing yourself. There is no obligation to buy salt from Culligan or pay for maintenance. They are pretty maintenance free and the salt can be purchased at a lot of places
   / Culligan and Septic #5
I have 2 semi custom system's in my basement one is a softner and the other is a carbon unit. I have them drain into the sump pit because they use more water than you would think to backwash and there is no reason to fill your tank. Have also seen them plumbed so they drain right on the lawn I have been told the salt concentration is not enough to kill the grass
   / Culligan and Septic #6
I've never heard that before. I searched for the other thread but couldn't find it. I've got mine plummed to my septic. My parents have always had their plummed to their septic. They replaced their 1st drainfield after about 15 years.
Thanks for all the responses so far guys. The Culligan guy said it purges about 35-40 gallons at a time.
I do not have a sump pit. I do have a drain in the floor, but the house is about 100 years old and my assumption is that this drain probably just goes into a dry well of some sort under the pad (the water tanks are on a cement pad, but most of the floor in the basement is dirt) If it is just a barrel of rocks under the drain, I can't imagine pumping 40 gallons of water into it at a time without dire consequences.
So it looks like some have had a good experience (or at least not a bad one) with pumping the flush into the septic. If it is true that you could pump it onto the grass, that would tell me that the salinity is not that high...or it would kill the grass. Right?
   / Culligan and Septic #8
I thing, like most things if life, it's an issue of all things in moderation. We just had a softener put in and I did as much reasearch as a could about draining it into the septic, we don't have a sump and I didn't want to drain it onto the grass. From my reading, the issue of salt water is not as big as an issue as the amount of water itself. If you have a family of five and a septic that's all ready near it's capacity due to number of users and design- then adding a water softner will put it over the edge. However, a couple with a 1000 gallon tank and is serviced at regular intervals shouldn't have any problems. I wouldn't worry too much about adding the water softner as long as you feel your septic has the capacity to take the addition water for recharges. The other thing that concerned me, that drain is a connection to my septic which can back up to my freshwater source- make sure it dumps into a trap or other method of avoiding siphoning from the septic line and that it's drain isn't the lowest, so when a back-up occurs you'll see it in the shower before in your fresh water supply.
Aaron
Thanks anojones, that makes me feel a lot more comfortable.
We had a new septic system put in when we bought the house 10 years ago and have it serviced regularly. There are 6 of us (with two bathrooms). The septic tank is 2,000-2,500 gallons with 7, 100' leech field lines. More than enough (in my layman's opinion /forums/images/graemlins/smile.gif ) Since two of the kids are teenage daughters, I can't imagine adding a little water softner will increase the overall load very much /forums/images/graemlins/crazy.gif
   / Culligan and Septic #10
With the thought of what salt does to concrete, and to avoid salt water in my leech fields, my water softener discharge is piped to the ditch along my road. This kills the grass in my ditch and keeps it out of my septic tanks.
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A54757)
UNUSED WOLVERINE...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
2017 HINO 268 BOX TRUCK (A54607)
2017 HINO 268 BOX...
