Cub (MTD) Starting issues
   / Cub (MTD) Starting issues #1
JRobyn
Elite Member
Middle TN
Kubota L4330HST
I've seen lots of posts on here where engines will turn over slowly or "jerky", turning part of a turn and then stalling. It seems to be a common failure mode for single and twin cylinder Kohlers and Briggs. I acknowledge that this is sometimes due to inoperable compression releases, but I just proved another failure mode. The starter solenoid on most all of these mowers is a "universal" part and the internal contacts are not particularly robust. Changing the solenoid on my FIL's TroyBilt Pony made a HUGE difference in starter motor strength and RPM.
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A51222)
2016 FORD F-450...
John Deere X740 Mower (A50514)
John Deere X740...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
