MPVawter
- Joined
- Aug 16, 2009
- Messages
- 2
- Location
- Franklin, Indiana
- Tractor
- Cub Cadet LT1045, 1947 Farmall M, 1960 Farmall 450
I was mowing with my Cub LT1045 and shut it down it add fuel. Unfortunately, it hasn't started since. The engine cranks fine but does not try to start. On the first few attempts, the engine backfired through the exhaust. Now it only cranks....
So far I have done the following:
* Verified spark by pulling plug from cylinder, grounding plug to engine, and cranking. Appears to have good spark?? I also replaced the plug.
* Tested the fuel shut-off valve on the carburetor. It appears to be working.
* Verified that the float bowl is full of fuel.
* Replaced the fuel filter.
* Replaced the oil and filter. Engine oil level is correct.
* Verified that the flywheel key is intact
What am I missing??
What am I missing??
