CUB LT1045 (46") deck belt replacement
   / CUB LT1045 (46") deck belt replacement #1
anthem3
Lovettsville, VA
JD L118 and Cub LT1045
Having a **** of a time getting the new belt over the front or idler pullies. Almost seems like the belt is 3"-4" too short! This is an '08 before they redesigned with the side by side pullies.
   / CUB LT1045 (46") deck belt replacement #2
Here's a long-winded vid, not sure if it'll help -
Cub Cadet LT1045 Mower Deck Overhaul bearings and blades. Pt1 - YouTube
I have a Cub RZT50, different idler setup - I finally built an "anchor bar" with a hole in it big enough for the pointed end of brake spring pliers, positioned it within reach of the idler spring, drilled a hole for a bolt and now I take the spring off, install belt, re-attach the spring. Much less "blue air" while I do this job :=) Steve
199049 (A51243)
199049 (A51243)
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2025 Icon Electric Bike (A50324)
2025 Icon Electric...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
