Cub Cadet ZTT 50 (i1050) vs RTZ S 42
   / Cub Cadet ZTT 50 (i1050) vs RTZ S 42 #1
runrider
PA
None
I need a new mower by spring. The local service shop sells only cub cadet, so I don't have a lot of options. They have the full line of new Cubs, and they also have a used 2011 Zero Turn Tractor. Since my yard is somewhat large (1 acre, filled with fences and obstacles), and every square inch of it is sloped, I think I want either a RTZ S or a ZTT... Regular tractors will struggle with all the turns, and traditional ZT's aren't suitable for my hill, with their non-steered castor wheels.
The 2011 ZTT at the local shop is exactly what I want, and I can afford it... but its a couple years old, and has 112 hours on it (was used commercially). I'm afraid that I'll have a hydro go out in a couple years!
On the other hand, the RTZ S looks like it will be a great choice, and covers ground faster (by 1mph), but its a little more expensive, which puts it out of my budget. But, if its going to last significantly longer, then I'll pony up. It has a smaller deck (42 vs 50), and seems to have a couple fewer features.
Does anyone have experience with Cub Cadets EZT transmissions? How many hours can you expect out of them? Any other recommendations?
65 views and no bites? Lets expand a bit. After more research, the "EZT" transmissions look like disposables, so I won't be considering these cool machines anymore. I'm searching for a commercial version on ebay/craigslist, no luck so far.
I'm also now considering regular lawn tractors, and maybe even a z turn. How steep of a slope can a z-turn handle? I need to be able to make turns and head in any direction from anywhere on my slope, which I guess might be around 10 degrees. Can a ZT handle 10 degrees easily? My budget is 2500, and I'm mowing an acre of obstacles. Minimizing mowing time is more important than cut quality to me.
   / Cub Cadet ZTT 50 (i1050) vs RTZ S 42 #3
Sad to say, but 2500 doesn't buy you much in the catagory you are looking in. As you are already learning, there is a lot of value engineering going on at that price level. Consider used or biting the bullet and increasing you budget by another grand for new. You seem to have a lot of tricky ground to mow and cutting corrners now will most likely mean spending even more later.
I have a Deere x304 that I absolutely love. I don't have quite as much lawn as you, but like you I have obsticals o'plenty and a fairly serious grade change between the front and back yards. It is one of the few tractors that has 4 wheel steer so you can turn quite tightly around the trees and only 1 transmission to worry about.
Good luck!
PS I also looked at a 1050 when I bought mine.. came very close to buying one but the x304 was much nicer.
   / Cub Cadet ZTT 50 (i1050) vs RTZ S 42 #4
I would suggest looking for a good used garden tractor 44-54" cut - like the Cub Cadet 2165-2500-3100 series shaft drive series with Kohler engines or the John Deere X series - the X304 has been given good reviews.
These machines were around $4K new and if you can find one that the owner took care of and upgraded to a bigger machine you should be in the 1800-2000 range - with 150-400 hours.
Carl
Good luck!
I'm OK with finding some lightly used commercial equipment. My last machine was a 1976 wheel horse c-120... I rode her hard for three years, then sold her for what I paid for it after the brakes quit working very suddenly on the hill...
How steep is too steep for a beefy commercial ZT?
Carl
Why a GT? All I do is mow. I have standalone machines for tilling and snowblowing.
   / Cub Cadet ZTT 50 (i1050) vs RTZ S 42 #7
They are built better, HD and with transmissions, decks and such that will last 20-30 years if taken care of. I have a CC 1811 since new in 1990 so 22 years and 750 hours, still on same engine, deck bearings, transmission etc.
I have a ZTR now, its a Ferris commercial IS2000 model weighs 1150 Lbs, 52" cut and I cut 2.5 AC and do a lot of clean up in the fall as well. I got a deal on a leftover 2009 model in 2010 $7K and now the same is $8500 range.
The ZTRs on DRY slopes are OK to 15*, maybe 20* but when its wet or damp grass the slopes can be tricky as there are no brakes or steering wheel on a ZTR - the drive wheels are the brakes and the steering.
Your lawn @ 1 ac is not too big, but big enough for a small ZTR, 48" would be fine, and you can find a used one for $3-3500 liek a Scag Tiger Cub, Exmark, or Ferris IS500. Most of these at this price point will have 400-1000 hours.
On the other hand you can find a number of used GT's in the 1500-2000 range in nice shape 100-300 hours on line today. So for the money you can get a newer GT close to commercial duty, with less hours than a ZTR for less money.
Carl
   / Cub Cadet ZTT 50 (i1050) vs RTZ S 42 #8
runrider,
If you are shopping Cub Cadets I would recommend that you look at the high-end Residential Z-Force series(have some commercial-grade features) or the TANK commercials if you want the reliability of a commercial unit. I'm a little leary of the quality of the low-end RZT series.
Thanks for all your inputs. The lady wouldnt let me spend the dough on a commercial unit, and I managed to find a really good deal on an almost new i1046 that I couldn't pass up, despite the RZT issues. Wish me luck with the new cub! I'll be back to the forum when the hydro dies in a year or two. Thanks!
   / Cub Cadet ZTT 50 (i1050) vs RTZ S 42 #10
Yeah, we all need the blessing of our Financial Advisor(aka, the wife:0) You will probably do well with that RZT46 and the HydroGear EZT tannies aren't "bad" drives, just not up to a lot of hours mowing at a time like a landscaping pro would do. I doubt you will be having any problems in a year or two. Let us know how you like it after mowing with it a while. Congrats!!!
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2011 Chevrolet Cruze Sedan (A50324)
2011 Chevrolet...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
