Cub Cadet zero turn 42 inch model 364.
   / Cub Cadet zero turn 42 inch model 364. #1
gobare1
Cub Cadet 42 inch zero turn model 364
Replaced a very worn pto belt and the PTO was disengaging fine before belt replacement. Now the PTO does not disengage which in turn the blades keep turning.
There is a belt tensioner pulley thinking I might be able to adjust that.
Ideas anyone?
   / Cub Cadet zero turn 42 inch model 364. #2
Did you use an OEM belt when you replaced it, or a generic off the shelf supposed to fit belt.
   / Cub Cadet zero turn 42 inch model 364. #3
Sounds like maybe the pto clutch went bad. Think I would unplug the clutch and see if deck still runs.
2016 Ford Escape AWD SUV (A50324)
2016 Ford Escape...
2014 Range Rover AWD SUV (A48082)
2014 Range Rover...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
Steel Truck Bed (A50860)
Steel Truck Bed...
2016 Cadillac XTS Sedan (A48082)
2016 Cadillac XTS...
