Cub Cadet Z Force S 60 No forward or reverse
   / Cub Cadet Z Force S 60 No forward or reverse #1
Oletrapper
Kentucky
John Deere 2040, John Deere 5410, John Deere 825i Gator, John Deere 265 mower, John Deere 14T baler, John Deere #9 mower
I have a Cub Cadet Z Force S 60. I mowed the back 10 and went to the house afterwards. Washed the mower off and now it will not move. No forward or reverse. Any ideas? Thanks, OT
   / Cub Cadet Z Force S 60 No forward or reverse #2
Is it possible there is a neutral mechanism that disables the hydros to allow manually pushing it? Perhaps that got bumped during washing it and it's in manual neutral?
   / Cub Cadet Z Force S 60 No forward or reverse #3
I think the rear drives [hydro pumps ] are belt driven, too. Maybe the belt is a little loose and she will take off when they dry.
   / Cub Cadet Z Force S 60 No forward or reverse #4
Interesting...my Kubota broke a tension spring on the hydro system. I parked it...went to go...nothing. crawled under it and saw the spring hanging there...
Check for tension.
Been awhile but I finally made it back. Found the problem. The hydro drive belt fell off the pulley on the engine. :-( The bracket that should hold it from falling off got bent somehow. All back together and running. Thanks for your input and suggestions. Oletrapper
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2015 International DuraStar 4300 Ambulance (A51692)
2015 International...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Deere 325G (A50123)
Deere 325G (A50123)
2015 Ford Explorer AWD SUV (A51694)
2015 Ford Explorer...
