Cub Cadet Z Force L60 Blades cutting off and on
   / Cub Cadet Z Force L60 Blades cutting off and on #1
semc
Cub Cadet Z force L60
I have a cub cadet zero turn. I recently had a new electric pto installed. Mowed fine for a while but now the blades will sometimes cut off and on depending on how you move the handlebars. I returned it to the shop and they could not get the problem to duplicate.
I'm thinking there is a bad switch somehow connected with the movement of the handlebars. I would appreciate any suggestions or things to check. Thanks
   / Cub Cadet Z Force L60 Blades cutting off and on #2
Reverse safety switches. Most likely there is one for each Z turn lever and one is bad and the other is going bad or you are bumping it and setting off the switch.
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
Splash 10ft 2,100 Gallon Water Tank Truck Body (A52377)
Splash 10ft 2,100...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
