Cub Cadet Z force 50 issues
   / Cub Cadet Z force 50 issues #1
kvaughan0513
Cub Cadet Z Force 50
Hi! I was wondering if anyone could help me diagnose the problem with my Cub Cadet Z force 50 mower. An issue started about 2 months ago where it would turn off after a couple hours of mowing. The handles would lock up and it would not go anymore until a "cool down" period after which it would start back up and continue mowing. I am now having an issue with the mower not starting at all (replaced the battery) and also just replaced the starter. I have changed the fuel filter and also removed the fuel shut-off solenoid. At a loss for what to do next. I appreciate any suggestions!
   / Cub Cadet Z force 50 issues #2
:welcome:
To TBN Kvaughan.
   / Cub Cadet Z force 50 issues #3
Hmmm, a common denominator. What is the model number off the chassis?
   / Cub Cadet Z force 50 issues #4
Kvaughan0513,
I could be off base here, but it sounds like the ignition coil has an issue that shows up when enough heat causes expansion and shorts it out. And now its expanded enough to make no continuity at all in its coils even when cold?
The reason I bring this up is that years ago I had a unit that went this route.
Gene
   / Cub Cadet Z force 50 issues #5
Just throwing parts at the problem is not the way to go. Don't understand why you would replace the starter when the issue is the unit stopping after mower for a while.
I see that your engine is air cooled. Have you checked under the fan shroud? Could be a mouse nest or a lot of grass preventing the engine from cooling properly.
Richard
PALLET OF FILTERS (A45333)
PALLET OF FILTERS...
New/Unused 10ft x 20ft Single Garage Metal Shed (A44391)
New/Unused 10ft x...
PALLET OF UTILITY GATE (A45333)
PALLET OF UTILITY...
2011 INTERNATIONAL WORKSTAR 7500 FLATBED TRUCK (A45333)
2011 INTERNATIONAL...
2018 KING KUTTER MFG  CHASSIS TRAILER (A45046)
2018 KING KUTTER...
New/Unused 20ft x 40ft Container Shelter (A44391)
New/Unused 20ft x...
