Cub cadet volunteer leaking oil
   / Cub cadet volunteer leaking oil #1
bebop86
NJ
my volunteer with the Kohler 624 engine is leaking from the bottom- I think it is oil but not sure- since the whole bottom is a skid plate I can not see- it is not leaking from the filter or the oil pan so really not sure - Also very hard to start in cold weather takes forever even with choke on- I am assuming it is oil but any help would be appreciated thks
   / Cub cadet volunteer leaking oil #2
If it looks, feels and tastes like oil, it probably is oil. There's a gear case above that plate too.
If you've run the engine or gear case dry of oil, that might make it hard to start otherwise the two conditions are probably not related.
   / Cub cadet volunteer leaking oil #3
If the oil smells like gas it is probably engine oil. If it smells like dead dinosaurs,:rolleyes: it's gear oil. :D
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
UNUSED FUTURE MINI SKID STEER TRENCHER (A51244)
UNUSED FUTURE MINI...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
2019 BOBCAT E35I EXCAVATOR (A51242)
2019 BOBCAT E35I...
