Buying Advice Cub Cadet TANK S-series 60" cut
   / Cub Cadet TANK S-series 60" cut #1
possomJ
Virginia
LX186 JD
What experiece have you had with Cub's Tank S60 Kal engine?
   / Cub Cadet TANK S-series 60" cut #2
When you say Kal engine I'm not sure which you mean.
I have a tank SZ 60 with the 27 HP Kawasaki engine. Purchased in layout 1 yr ago.
62 hrs on the clock and no problems. Engine runs very well. We mow 15 or so acres.
When looking at competing models from JD and Kabota I liked the build of the Cub better.
Also, liked the steering wheel type drive. My property is hilly and with the stick drive you need to continuously compensate when going across the hill.
No so with the steering wheel. The front wheels are not casters like other ZT's. They are power assist steerers. When side hilling if you let go of the wheel it still tracks straight. Try that with a stick drive.
If your property is bumpy, hilly etc a 60 inch deck may not mow as well as a narrower one.
Unverferth Brent CPC PT 16' Disc Ripper (A50120)
Unverferth Brent...
Electric Parts Movers (A50121)
Electric Parts...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
8x18 Metal Rack Hay Wagon (A50774)
8x18 Metal Rack...
John Deere 1023E (A50120)
John Deere 1023E...
