Cub Cadet RZT-S Steering Issues
   / Cub Cadet RZT-S Steering Issues #1
slow84ta
Buffalo, NY
Looking
My friend has a Cub Cadet RZT-S Which is the Steering Wheel version. His front wheels are out of sync while steering to the right. Any idea's what it good be?
   / Cub Cadet RZT-S Steering Issues #2
This image is taken from the RZT-S Operator's Manual. Besure to perform all service at appropriate times. It also sounds like this maybe a Wheel Alignment or Drive Control Linkage problem. It's important to make sure all tires are first inflated at the proper PSI, check operator's manual. Check out this Mower Manual Pro site on how to fix alignment issues. They should be able to help you fix this issue or of course contact your local Cub Cadet Service Center. I hope that helps. Wheel Alignment And Drive Control Link Adjustments - Cub Cadet RZT-S Professional Shop Manual [Page 54]
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
175 Gallon Spray Rig Pull-Type (A52128)
175 Gallon Spray...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
2020 Lincoln Naultilus (A50324)
2020 Lincoln...
Wolverine Quick Attach Stump Grinder (A50514)
Wolverine Quick...
