Cub Cadet RZT 50 Ignition Problem
   / Cub Cadet RZT 50 Ignition Problem #1
souldonut76
Germantown
Cub Cadet RZT 50
Hello,
I bought a used Cub RZT 50 a couple of years ago. It will not start with the key. It will start if you jump the positive battery terminal directly to the starter or by jumping the solenoid posts. I have already replaced the parking brake safety switch, and have checked the PTO switch, one of the neutral switches, and the ignition switch with a multimeter, all are working as expected. It should be noted that my seat switch seems to maybe have been disabled. There is only one wire going to one of the two posts, but best I can tell that shouldn't keep it from starting and it actually has started with the key without that, but only once. The PTO light lights up when I turn the key, but like I said, I tested the PTO switch and it's fine. Those lights don't make any sense, the parking brake light comes on if the arms are not in the neutral position, so it's hard to say what causes those lights to light up.
My fuse is good. I have power at the solenoid. The body grounds connected to the solenoid seem to be good. I do not have power at the small pink wire on the solenoid... which I believe indicates a safety interlock issue. But, as I said, I've checked all but the one neutral safety switch (I know, I need to check it... but what a pain).
The only time it ever started with the key was after I replaced the solenoid. My theory is that either something is shorting, or something is not connecting, and my taking the solenoid loose jarred something which has since gone back to being shorted/not properly connected, but what?
What else do I need to check? I appreciate any help.
   / Cub Cadet RZT 50 Ignition Problem #2
I assume that this uses the standard MTD 3 pole solenoid as you spoke of the one trigger wire. What could possibly be related, though not terribly common is that solenoid ground. You had mentioned after the fresh install- magic it worked. Look real close that is getting a good ground and clean that ground cable end real good. You can confirm that this area is good simply by sending 12 volts to that trigger terminal on the solenoid. Common terminals that seem to see more issues are the main battery lugs, the B terminal on the ignition switch and the fuse holder itself. I tend to start there and if unsuccessful- dive in for the kill.
   / Cub Cadet RZT 50 Ignition Problem #3
What year is you RZT and what engine does it have?
Richard
   / Cub Cadet RZT 50 Ignition Problem #4
souldonut76
Have you been able to resolve the problem?
If so, let us know, if not, supply the info I requested.
Richard
   / Cub Cadet RZT 50 Ignition Problem #5
yeah---I would like to know if this problem has been resolved also
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRACTOR (A51243)
2012 MACK PINNACLE...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
1268 (A50490)
1268 (A50490)
2009 Ford Escape Hybrid SUV (A50324)
2009 Ford Escape...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
