Cub Cadet RTZ50 wiring
   / Cub Cadet RTZ50 wiring #1
Barryly
cub cadet rtz50
My rtz50 wouldn't start . Long story short I jumpered the orange/white wire from the key switch to the solenoid . It started and operated ok except when I engaged the pto it died . What do I jumper to get my blades turning ?
   / Cub Cadet RTZ50 wiring #2
Berry,
Welcome to TBN
:welcome:
Check for correct operation of the seat switch and the reverse shut off switch.
Sorry I don't have a wiring diagram for that machine.
Richard
OK - quick search on the internet showed this:
Cub Cadet RZT5 Manuals and Diagrams
Cub Cadet website and the manuals include the wiring diagram. To get the correct manual, you will need to know your Factory model number:
From the site"
Using the right factory number ensures you'll find the correct spec sheet. Using the wrong factory number can lead to using the wrong parts on your RZT50 mower.
Richard
Thanks for the welcome and reply . I have a wiring diagram , I am not that good at DC voltage but I will check the reverce switchs .
   / Cub Cadet RTZ50 wiring #4
Richard
Here is what I do some times when there are multiple paths for the current to flow to the clutch. Take and print out the diagram, then use multi colored pens to trace the lines to or from the clutch.
After typing this, I just realized that your first post is not clear. You said:
"It started and operated ok except when I engaged the pto it died "
Did the engine stop running or the PTO does not work?
Richard
The engine stopped running .
2025 Wolverine MAD-12-12D 36in Auger Skid Steer Attachment (A55851)
2025 Wolverine...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2018 Altec DC1317 Towable Brush Chipper (A55851)
2018 Altec DC1317...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2014 Ford F-150 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
