cub cadet pto
   / cub cadet pto #1
th41004
Hi I have recently purchased a 2000 cub model 2206. After I run it for awhile if I turn the deck off and back on it wont clutch up right just humms. Is this a common problem? What do I need to do.
   / cub cadet pto #2
This is an electric clutch and the engine cooling exits the front of the tractor, so I suspect the heat is causing the internal components of the clutch to expand and thus not engage.
Take the front grill off and try using some point lubrication (with the little red tube) using wd 40, then some white spray on lithium grease to free this area.
I have a cub 1990 1811 hydro w/400 hrs no problems with the clutch to date..
Carl
2016 Ford Explorer SUV (A50860)
2016 Ford Explorer...
2017 Mahindra 85P 4WD Tractor (A50860)
2017 Mahindra 85P...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
2020 KUBOTA RTV...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
