Cub Cadet PTO
/ Cub Cadet PTO #1
glenj44
Cub Cadet 1864
I have a cub 1864 that has a pto problem. One person said that it was the battery so I change it. But it wasn't the problem.
With the pto engaged the battery light comes on must mean it is draining the battery at an alarming rate. It will run fine until I get into a little taller grass. Now since the new battery it will not engage. Throw the switch and within 15 seconds it blows a fuse.
Do I need a new pto or can I fix it? Tractors to good to go unused.
/ Cub Cadet PTO #2
The cub PTO should draw 3-4 amps in operation roughly, if the old battery and amp meter were lighting up it's drawing too many amps also when running in high grass this stresses a weak PTO..
Replace the PTO - new $250 range, used $60 range. Good Luck.
Jacto 500 Gallon Pasture Sprayer (A62183)
Jacto 500 Gallon...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
Bad Boy Stand On Mower (A64047)
Bad Boy Stand On...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
(8) PLASTIC PALLETS (A63745)
(8) PLASTIC...
John Deere 385 Baler (A64047)
John Deere 385...
