cub cadet paint help
   / cub cadet paint help #1
Undercover
I could use a little advise from anyone who has painted with it.Right now i'm painting a CC 1872 and i have the Cub Cadet yellow 759-3263.Just wondering what people use for reducer and hardener and what ratio.I have been told by a guy that the paint is pre mixed and he just uses hardener.Have not tried that yet.I would like more input before i do it.it is $$$.I would just like a starting point.Also what kind of hardener reducer?Thanks for any help or advice John
   / cub cadet paint help #2
I just use the hardener tractor supply sels for their valspar paint and a cheap enamel reducer.
Look at a can at tractor supply to see what they use for a thinner
You need to reduce it to spray it.
And no hardener it will take a day to dry.
Tractor supply federal yellow works good for cub paint and is a third the price.
It's just a cheap synthetic enamel
   / cub cadet paint help #3
there is a guy on you tube who restored a cub cadet. totally stripped, primed and painted it. he used tractor supply (valspar) paint on it. go to you tube, type in 500passwords. he has a ton of videos, many on his painting techniques. very amusing but also informative. just a backyard mechanic like us.
Thanks for the help.I have talked with a few people who paint cc and the one thing that they all have in common is they all use a different ratio and different products.I really in joyed the you tube guy he did start using the cc paint.
thanks
INOP/NON-RUNNING 2009 Mack GU813 Truck, VIN # 1M2AX13C09M004546 (A44391)
INOP/NON-RUNNING...
2015 MACK GU GRANITE (INOPERABLE) (A45046)
2015 MACK GU...
Ryobi Sliding Compound Miter Saw (A44391)
Ryobi Sliding...
2015 FORD F750 BOX TRUCK (A43003)
2015 FORD F750 BOX...
2011 HINO BOX TRUCK (A45046)
2011 HINO BOX...
10'x20' Single Garage Metal Shed (A44502)
10'x20' Single...
