Cub cadet M60 tank
   / Cub cadet M60 tank #1
jdhacker
Ky
Cub 3240 Poulan pro graden tractor
Hello everyone I bought this mower as a project. Got the mower cheap, said one side was weak so they sold the motor off of it. I found a engine got it running. The right side is weak forward But has the same power as the other side in reverse ? That dont make any sense to me. If that side pump was weak would't it be weak forward and reverse?
   / Cub cadet M60 tank #2
Three things that I can think off. The linkage on the forward weak side is loose allowing extra movement. Bad check valve in the pump allowing bypass in the forward directions or a problem with the wheel motor.
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A50322)
2015 John Deere...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
PT Canal Pump (A50121)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2014 New Holland H7230 (A50120)
2014 New Holland...
2002 Peterbilt 379 (A50120)
2002 Peterbilt 379...
