rtyndallnc
- Joined
- Aug 1, 2011
- Messages
- 31
- Location
- Angier, NC
- Tractor
- Bob-Cat Pro7000, Bob-Cat Pro6000,Troy-bilt Mustang RZT 50, Massey 1225, Long 460, Kubota ZD25
I have 2006 Cub Cadet M48-KW Tank that has a couple of problems I need help with. Bought this used and only had it a little while.
First, I was having an issue with it being hard to start. I had to play around with the choke while holding the key and it would start in about 20 to 30 seconds. I changed all the fuel lines as they were old and crumbling. Replaced the fuel filter and checked/cleaned spark plugs and Put a new fuel pump on it. It now starts easier but while actually mowing if you hit a bump it acts like it's going to turn off but never actually does. Also when I engage the PTO it sounds like it's going to cut off yet never does.
Second problem is the PTO. It engages fine when I first start cutting but after using it for 20 to 30 minutes, if I turn off the PTO it does not want to start back. First time this happened I started driving the mower and the PTO kicked in. Same thing happened again so I tried that and it did not work. I was basically finished mowing so I just parked it. I have noticed this mower will cut in reverse, not sure if that is because it is a commercial mower or if something is wrong there. I know my Troy Bilt residential RZT will not cut in reverse.
Any and all help appreciated
