Cub Cadet LTX1050VT not charging
   / Cub Cadet LTX1050VT not charging #1
mjw357
Platinum Member
The Sticks, Ohio
Kubota B3200
Wife went to start tractor this afternoon, no go. Checked battery, 11.8v or something. Jumped it to start, 10.something across terminals. So the ignition/headlights are pulling it even lower while running, obviously not getting anything from the charging circuit. New battery as of last September.
Have battery on charger as I type this. Engine is B&S 24HP twin. Single black wire running up under flywheel area. Green connector to yellow wire to regulator/diode. Red wire running from regulator/diode out to tractor. Reg/diode is about 2" square by 1", bolts to engine shroud.
What voltages am I looking for? Easy way to test alternator/stator?
   / Cub Cadet LTX1050VT not charging #2
Should be two wires running up to stator under flywheel. Disconnect and check for AC volts. Check that the regulator has a good ground to engine block.
   / Cub Cadet LTX1050VT not charging #3
mjw357, You have what appears to be the 5/9 regulated system. connect the red lead of a volt meter to the single green connector, and the black lead to ground, set the meter for AC volts start and run the engine at 3600 rpm, full throttle, and should should get a minimum of 28v with the 5 amp system or 40 v with the 9 amp system. Now take into account that you won't know what system you have because the only difference is the size of the flywheel magnets.
Make sure you are getting battery voltage to the red wire from the tractor, also make sure the voltage regulator is grounded properly.
Started mower, black wire just above idle about 30vac, at full throttle 42vac. Connected regulator, at full throttle, only getting about half a volt DC.
There is 12.8v at red wire.
Ordered replacement for part # 491546.
UPDATE: received new part and installed. Now charging at 14.1v. I guess these parts just decide to go out once in a while.
   / Cub Cadet LTX1050VT not charging #6
Yeah! Thanks for the followup report!
- Jay
2008 GMC C7500 Altec LRV55 55ft Forestry Bucket Truck (A50323)
2008 GMC C7500...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
2010 GMC Acadia SUV (A50324)
2010 GMC Acadia...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A51219)
2021 FREIGHTLINER...
