Cub Cadet LTX1050VT Keeps Throwing Drive Belt
   / Cub Cadet LTX1050VT Keeps Throwing Drive Belt #1
AlwaysBeMowing
Cub Cadet LTX1050VT
Started it up and noticed the mower wouldn't move. Belt had come off the trans pulley and shredded the plastic fan.
I put the belt back on, but as soon as I released the brake, it made an awful rattling noise, and the belt jumped off again.
Any ideas what could be causing this?
Some people are saying idler pulley. I thought maybe the trans gave up the ghost, but I can still spin the pulley so maybe it isn't seized?
Thanks for any help. Trying to get the lawn done once more before winter.
   / Cub Cadet LTX1050VT Keeps Throwing Drive Belt #2
Did you get it on right? Is the belt streched? Is one pully or bearing bad? Theres many things it could be.
   / Cub Cadet LTX1050VT Keeps Throwing Drive Belt #3
Welcome to TBN. One would assume that a new belt should be installed rather than just put back on if it got into the fan. If the pulleys look good, i'd almost bet that a blade or two on the fan is mushed down, rolling the belt off and sounding like a card in the spokes. It sometimes happens too that the splines in the driven pulley become worn, pulley comes loose.
   / Cub Cadet LTX1050VT Keeps Throwing Drive Belt #4
Check the tensioner and other mechanical items. If everything is good and tight, put a new belt on.
The belt on my zero turn kept coming off last year. Turned out it must have just been stretched because I put a new belt on after checking things over and haven’t had a problem since.
   / Cub Cadet LTX1050VT Keeps Throwing Drive Belt #6
If bearings/shafts/pulleys are all ok... Belt is compromised and only replacing it will solve issue....
Dale
   / Cub Cadet LTX1050VT Keeps Throwing Drive Belt #7
These mowers are bad about shredding the fan when the belt comes off. Did you use the diagram to put the belt back on. Could have missed a pulley.
But the drive belt is a breeze compared to the deck belt.
Unused Set of 4 10-16.5 Tires (A42021)
Unused Set of 4...
2015 T800 GIN POLE TRUCK (A41853)
2015 T800 GIN POLE...
2008 IC Corporation PB305 Bus (A42742)
2008 IC...
2010 IC Corporation PB105 Bus (A42742)
2010 IC...
JCB  950 MAST FORKLIFT (A45046)
JCB 950 MAST...
2023 Ford Ranger Pickup Truck (A44572)
2023 Ford Ranger...
