Cub Cadet LT1042 Lawn Mower Won't Turn Over
   / Cub Cadet LT1042 Lawn Mower Won't Turn Over #1
pennypatterson
moselle ms
cub cadet lt1042
I mowed some grass that was probably too tall and had a stick in there that consequently pulled the wire loose from the PTO Clutch and the other end around the side of the motor. Can't really see in there or get hands in there but when wired back underneath by feel and to the wire on the side, it won't crank. It has sat up for a few weeks and has since gotten colder, but not freezing just in the 50's. I am a girl (not a mechanic) and thought maybe it has something to do with the wiring or the fuse?
If anyone can help with info, I would sure appreciate it. Too heavy to pick up and put in truck.
   / Cub Cadet LT1042 Lawn Mower Won't Turn Over #2
First, wetcome to TBN from Oklahoma.
Recheck the wiring repair you did, and yes, check the fuse. Also, check that safety switches to make sure your stick didn't damage one of them or their wiring. Also, post your question on the Cub forum also. Not many people look in the New Member area.
Ken
Thank you so very much!! It was just the fuse! Such an easy quick fix. I thank you, my yard thanks you and I know what I will be doing tomorrow!
   / Cub Cadet LT1042 Lawn Mower Won't Turn Over #4
You're very welcome. Glad I could help you get back to yard work :)
Ken
   / Cub Cadet LT1042 Lawn Mower Won't Turn Over #7
Welcome to TBN :)
I moved your thread to the Cub Cadet L&G forum.
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2013 Case 84in Hydraulic Hopper Sweeper/Broom Skid Steer Attachment (A49461)
2013 Case 84in...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
