Cub cadet gt1554 pro problems
/ Cub cadet gt1554 pro problems #1
Shae
Cub cadet gt1554
My cub cadet gt1554 is having pto problems. The clutch will engage and then stop right away. Sometimes doesn’t even start and other times will start for half a second then once in a great while go for a few seconds. Already replaced pto switch, and battery. Is there a relay somewhere or do I need a new clutch?
/ Cub cadet gt1554 pro problems #2
Welcome. You may need a new clutch. Test that you have and maintain power at the clutch connector first. One other thing that sometimes happens is the wire or switch in the reverse sensing circuit will give you trouble. Before you engage the deck, turn on the mow in reverse feature and see if it then runs up.
