Loader Cub Cadet compact tractor/woods loader
   / Cub Cadet compact tractor/woods loader #1
adamsdj1
Bought the tractor with the woods loader attached from dealer. Has worked fine for 2 years (160+ hours). Dsconnected hydraulics to service tractor. Now the loader goes up and down but does not tilt forward/backward. Just kind of swings. Help?? Have tried multiple combinations for the 4 lines... no luck Don't suppose anyone has a diagram? The loader manual and the tractor manual have not been much help..
   / Cub Cadet compact tractor/woods loader #2
One thing that you may want to check is that the quick connects are fully attached and engaged. It is possible for them to look like they are properly connected and yet they are not fully attached. If they are not together properly then the check valves will not allow fluid to flow through them.
A note of caution - if you want to check if the balls in the valves are moving freely remember that the hydraulic fluid is under great pressure and can be dangerous if sprayed at you. Put a rag over the fittings before attempting to push the balls in.
Hope this helps.
JN
   / Cub Cadet compact tractor/woods loader #3
As mentioned above by Nelson, QD's seem to be the biggest problem. May have to rehook several times to get to work.
   / Cub Cadet compact tractor/woods loader #4
Sounds like they're not going back to the proper position.....are they color coded? Sometimes they have a colored tab "somewhere" along the hard line, if you trace it you should (hopefully) see it.
And, as others have said, you have to seat the Quick disconnects fully, they may look like they're attached and feel like they're attached, but they're NOT attached.
Thanks all.. we'll make sure they connect securely... Scoutcub.. You're right on what we think is the problem... unfortunately the color codes for the bucket are not in the same place/order as those on the side of the tractor, and there is no diagram in the manual for the loader to tell us what goes to what..
Toro Mower (A50324)
Toro Mower (A50324)
Little Giant Poly Water Tank (A50515)
Little Giant Poly...
2012 FREIGHTLINER CASCADIA DAY CAB ROAD TRACTOR (A51243)
2012 FREIGHTLINER...
Farmall 460 Tractor (A50514)
Farmall 460...
UNUSED FUTURE MINI SKID STEER TRENCHER (A51244)
UNUSED FUTURE MINI...
Mayrath 10 x 31 Truck Auger (A50514)
Mayrath 10 x 31...
