Cub Cadet 8354 won't disengage 4 wheel
   / Cub Cadet 8354 won't disengage 4 wheel #1
BobAi
Waterford, CT
5384 Cub Cadet
Hello,
I am a new member and just purchased 8354 with backhoe and front end loader. Only 400 hrs. Unfortunately, I am unable to disengage the front wheel drive after putting it into 4 wheel drive prior to transportation. I am planning on taking it in for service but it will take some time to get transportation arrange. Wondering if there is some easy fix, what or how serious the problem might be. More importantly will I do any damage leaving it in 4 wheel drive if I am only driving it on dirt?
Bob
   / Cub Cadet 8354 won't disengage 4 wheel #2
It will not hurt to leave it in 4 WD
The 8354 is the same machine as my older model Kioti DK 35. Just painted yellow and white, with a different loader and backhoe.
I always put my 4 WD in/out while moving with no load on the machine. Goes in/out much easier that way.
Also try lubing the linkage under the tractor where it goes into the transmission.
Thanks,
Used some penetrating oil and lifted the front tires of the ground. With a little coaxing it released and now is working just fine.
Bob
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2019 KENWORTH T880 (A50854)
2019 KENWORTH T880...
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
