jdoff
So I pulled in the garage after some tractorin' to change the oil on the 2007 Cub Cadet 6284 we bought a couple of months ago. It's only got 114 hours, so not even due for the first engine oil change, but I don't like the idea of seven-year-old oil (hydro filters were changed last year).
I drained the oil and took a sample to send to Blackstone Labs, and took the Wix 51085 filter off the shelf. After unscrewing the Cat 150-4140 filter from the engine, I saw that I had a problem. The Wix 51085 is about 5/8" larger in diameter than the filter that came off of it, and there's no clearance near the frame rail for a filter larger than the original.
Cat, Cub Cadet, and everybody else with an equivalent filter apparently thinks that the 150-4140 is 3.66" despite the one in my hand measuring just under 3". After much searching I think that a Wix 51348 is the right part. My Wix dealer is closed for the day so I can't get one until Monday...does this sound like the right filter? Cub Cadet 6284 owners, what filters are you using?
