Cub Cadet 3206 series Hydraulic Lift Lines
   / Cub Cadet 3206 series Hydraulic Lift Lines #1
GTSRider
Cub Cadet 3000
My 3206 series, bought used 3 years ago had the hydraulic lift lines hooked up backwards , when I bought it, so
up is down , and down is up, with the lever. I now have the fender body off, to remove , and clean out gas tank,
so as long as I have access to hydraulic lines , I was going to reverse them in order to correct problem.
My question is .....how do you disconnect these lines ?
I don't want to do any damage to them, as they are old.
Thanks,
Pete
Hudson Valley, NY
I think I get it....lines must be relieved from the control block, with new O-rings installed.
Sound correct ?
Pete
2022 RAM 2500 (A50854)
Zero Turn Mower (A48082)
Zero Turn Mower...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
New Holland B95 Backhoe (A50490)
New Holland B95...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
