Cub Cadet 3-point doesn't move
/ Cub Cadet 3-point doesn't move #1
mudweiser
Cub Cadet 8404 compact tractor, 3-point won't go down
/ Cub Cadet 3-point doesn't move #2
Does it have any weight on it? I had one that wouldn't go down by itself, it had to have something hooked up
it started going down slow, i had the bushhog on it last week and took it off, so now there is nothing on it and they won't go down.
/ Cub Cadet 3-point doesn't move #4
Have a fat buddy stand on it. No, really this will get it down. All most all 3 points are gravity down. 99% of tractors are made this way, pressure up gravity down. There is usually a flow control valve some where in the down side of things. It controls the rate at which it goes down due to the different weights of implements. On my tractor the valve is a black knob down between my legs as I set on the seat but all are a little different.
You need to be able to adjust the down rate. For example a small potato plow only weighs 40# or so while a 6' Bush Hog weighs 600#. If you have the rate valve set for the potato plow and throw on the Bush Hog with out adjusting it it will slam down. By adjusting the valve, which is like a water spickot, it chokes off the path for the hydro fluid making it lower slower and nice and smooth.
Chris
i forgot all about that control knob. I must have hit it with my foot. thanks alot for helping me out.
/ Cub Cadet 3-point doesn't move #6
Glad it was a simple fix.
Chris
2018 Nissan Rogue SUV (A61569)
2018 Nissan Rogue...
2018 INTERNATIONAL LT625 T/A MID ROOF TRUCK TRACTOR (A59909)
2018 INTERNATIONAL...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
Transfer tank (A61567)
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
Adams Tilt Trailer (A63118)
Adams Tilt Trailer...
