Cub Cadet 2400 will not start again
   / Cub Cadet 2400 will not start again #1
Hawaii Marine
cub cadet sc 24000
Eight hours on this new machine and it is doing the same thing today and Gods Countrys quick cure is failing to start it. Is this a common problem on this tractor?
   / Cub Cadet 2400 will not start again #2
Did you locate the foot brake switch? It is located under the tractor. Follow the foot brake arm to a plate welded to the arm that trips a switch. I would inspect the switch and harness just for my own knowledge. I suspect that is the problem. Could still be the seat switch or ignition related however.
At this point I see no reason why the dealer shouldn’t be involved. I’m sure it’s not a big deal, but I do understand your frustration.
Good luck
   / Cub Cadet 2400 will not start again #3
Since the 2400 is diesel, I don't think it's an ignition problem... mostly because there is no ignition system. If the starter turns over and it doesn't start, then I suspect a fuel problem. Since you mentioned (I think) in the other post that it clicks, then I'd say maybe the starter is bad. If by click you really meant it does nothing, then I'd say it's one of the kill switches already mentioned.
At any rate, I 100% agree you should just call the dealer and have them fix it. It's new and, therefore, under warranty. In short, this is not your problem. It's the dealers problem.
Aloha Hozen, Thanks for the help I called the dealer and they are sending someone to look at the problem today.
Aloha Gods Country, When the mechanic gets here i will make sure he points out the exaxt location of these saftey switches. Thank you for the advice.
UNUSED FUTURE 4 GAUGE 25' JUMPER CABLES (A51243)
UNUSED FUTURE 4...
(4) Rolls of Barb Wire (A50515)
(4) Rolls of Barb...
40' CONTAINER (A51244)
1998 JOHN DEERE 643G FELLER BUNCHER (A51242)
1998 JOHN DEERE...
3 pt AerWay (A50514)
