Tdraym
I have a 2206 cub w/ Koehler 20 hp, started up just fine the last 3 days, tried to start today, took a little bit of time turned off key, tried 2nd time nothing happened, didn't turn over yes brake pressed, tried 3rd time and it started, so went and cut grass for 1/2 hr. when I shut off pto mower deck the tractor died and that's not normal. Tried to restart and no turnover not even clicking, checked battery OK chkd fuses ok, seat switch has been jumped for years. So what is the next step? I see we have brake switch, a safety switch some ware in line under tractor and ignition key switch w/ lights position, What is the most likely to go first, I see nothings cheap and elect. parts aren't easy to return and not to easy to find locally, contacts on starter all clean. So if any suggestions please let me know Thanks , Tdraym
