cub cadet 2185 hydrostat
   / cub cadet 2185 hydrostat #1
hayjake4
I have a 2185 that lost forward completely, I have checked the linkage ( I even completely removed the linkage from the hydrostat pump and manually operated the trans with the same results. I have replaced the 2 check valves on the pump and changed the fluid annd filter. I am stating to see some of this series show up on ebay (1 has the exact problem as mine) please help.
   / cub cadet 2185 hydrostat #2
That's an odd one. As far as I know, all the 2000 series cubs from the mid 1990's to 2004 had the same aluminum cased transaxle with the same hydrostatic drive. I have not heard of many problems associated with them. Are you using a CC filter for the trans? I have heard of some off brand, off spec filters causing issues, where replacing it with a CC transaxle filter fixed the issue.
Joel
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
Toro Workman Cart (A50322)
Toro Workman Cart...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
Landoll Hauloll (A51039)
Landoll Hauloll...
