CUB CADET 2155
   / CUB CADET 2155 #1
DUKE1234
New to the forum and I have two questions pertaining to my CUB Cadet 2155
When hot the PTO will sometimes not engage, any suggestions?
I like many others would like to mow in reverse but am not sure of where to go to disable this feature. thanks
   / CUB CADET 2155 #2
I believe you have a electric pto on that model.
When it's hot, shut down motor. Turn key back on so you have power, engage pto.
You should hear a "click" when it engages.
Sounds like a connection is braking sometimes when it's hot.
If it was a short it would pop the fuse and not work at all.
Cubs usually have a switch on the reverse pedal rod. There's a metal tab that pushes on switch to prevent reverse mowing. Bend tab to one side to miss switch.
   / CUB CADET 2155
Thanks, riches I will try your suggestion
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
2015 Manitou MLT840-115 PS 4WD Telehandler (A50657)
2015 Manitou...
2019 Komatsu PC490 Hydraulic Excavator (A49461)
2019 Komatsu PC490...
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
