cub cadet 2150 losing power to back wheels
   / cub cadet 2150 losing power to back wheels #1
mark lucius
I have a cub cadet model 2150 with the gear drive system the mower does not have hydrostatic drive after about 15 minutes of mowing i lose power to the back wheels the engine and blades have plenty of power but the mower slows down and cannot go up even a slight incline any help will be greatly appreciated thanks.
   / cub cadet 2150 losing power to back wheels #2
Possibly a clutch problem? That unit has internal friction discs that can wear out. I have a 2165 and put a 2160 rear end into it. It uses separate friction discs for forward and reverse gears. The driveshaft bolts to the clutch assembly which looks alot like the hydro pump that I use to have.
   / cub cadet 2150 losing power to back wheels #3
If that is the Autogear drive, many use the go pedal as a hydrostatic and burn up the clutches. I was told that you've got to mash it and use the gears for controlling your speed. I also heard that new clutches were reasonable and better made now, so that is what I would try.
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
1272 (A50490)
1272 (A50490)
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53473)
2022 NEW HOLLAND...
