cub cadet 2146 PTO won't release
   / cub cadet 2146 PTO won't release #1
cardonster
cub cadet 2146 PTO won\'t release
pto clutch won't disengage even with wires unhooked - so, have to start unit with pto engaged. Any ideas???
   / cub cadet 2146 PTO won't release #2
Re: cub cadet 2146 PTO won\'t release
</font><font color="blue" class="small">( pto clutch won't disengage even with wires unhooked - so, have to start unit with pto engaged. Any ideas??? )</font>
You must have a mechanical bind. First I would check the clearance between the clutch disc and hub at three places around the clutch. You should have at least .020 inch gap. There are springloaded adjusting screws which can be backed out to increase the gap. The other possibility is the disc has rusted or stuck on the spline and will have to be removed and cleaned up. Put a light coat of lubriplate on the spline.
Bob B.
2015 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2008 GMC C7500 Altec LRV55 55ft Forestry Chipper Bucket Truck (A50323)
2008 GMC C7500...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Ingersoll Rand 2570 Skidloader Breaker (A50774)
Ingersoll Rand...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2012 Ram 3500 Crew Cab Mason Dump Truck (A50323)
2012 Ram 3500 Crew...
