Cub Cadet 2145 PTO Problem
   / Cub Cadet 2145 PTO Problem #1
MurrayL
Cub Cadet DRS 2145
Hi. I am having a problem with my old but well cared for 2145. Last year I replace the PTO pull and had no problems. This year though is another story. Every so often when I engage the pto it starts spinning but not at top speed, so the blades do not turn fast enough to cut the grass.
I checked all the pulleys, including the ones on the cutting deck and everything appears fine there. the electrical connection appears good. If The pto does turn at full speed and I shut it off, I can't get it to engage again.
Any ideas or suggestions would be greatly appreciated.
   / Cub Cadet 2145 PTO Problem #2
Sounds like a similar problem I had with my 2185, it was an ignition coil issue.
   / Cub Cadet 2145 PTO Problem #3
this happened to my 2166 and at was a bad deck belt,
   / Cub Cadet 2145 PTO Problem #4
Curious as to what you found wrong.
2023 CATERPILLAR 299D3XE SKID STEER (A51242)
2023 CATERPILLAR...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2018 KUBOTA MS-091 TRACTOR (A51243)
2018 KUBOTA MS-091...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52128)
2018 Dodge Ram...
