Cub Cadet 2140 Transmission
   / Cub Cadet 2140 Transmission #1
beaverdam
I have a CC 2140 that needs hydrostatic transmission work. The OEM price of $1100 plus labor for a replacement is prohibitive. I have not found anyone locally to repair mine at this time of the year and I do not have the knowledge or the manuals to do this. Anyone know of a used, rebuilt, remanufactured, or aftermarket replacement. I would be greatful. The numbers are: Tractor Model 135-232-100, Serial #295-453, other number on plate BO65G8; Decal on Transmission, Model #616-3080, Serial # 34-707
   / Cub Cadet 2140 Transmission #2
$1100+ is totally insane. You could try eBay, or scour the net for a used/rebuild/reman unit. Do you know off hand if this is a peerless or a hydro-gear unit? On the newer hydro-gear units, the hydrostatic drive portion of the transaxle just unbolts from the front (input end) of the diff. Real simple to R/R. Drop the driveshaft & remove the external hydro drive unit from the diff. Are you positive yours is shot & it's not a low oil, linkage or brake hanging up issue?
G/luck
Joel
I bought this unit used and took it to a shop that said they could replace the transmission for $300--the usual cost of a new transmission for a Craftsman, Troy-Built,etc. When they checked with two Cub Cadet dealers they got a price of $1100. They are not a dealer and have no way to cross ref. the trans numbers. I don't know the manufacturer. I have talked to two dealers and get the same price. Cub Cadet transmissions must be very good--at least the manufacturer thinks so. I am going to pick it up tomorrow and check the oil, filter, etc.
THIS USES A TRANSAXLE--TRANSMISSION, DIFFERENTIAL, AXLES ALL IN ONE CASE--WHICH MAY ACCOUNT FOR IT'S COST. INEXPENSIVE TO BUY-BAD TO REPLACE. /forums/images/graemlins/frown.gif CONSIDER THIS WHEN YOU ARE LOOKING TO BUY ONE.
Solved the problem. I traded it for a Cub Cadet 2166 with 37 hours on it. /forums/images/graemlins/laugh.gif
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
2015 Chevrolet 3500 HD (A50120)
2015 Chevrolet...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
