cub cadet 1882
   / cub cadet 1882 #1
mduggan901
My cub had been sitting for a few years. My question is; After checking fluids and found to be clean, is there anything I should do prior to trying to move/drive?
   / cub cadet 1882 #2
I just got out my Cub after six years. I had gone through it pretty completely before putting it away and I think I had even put Stabil in the tank
All I did was put a battery in it and turned it over to ensure that it wouldn't start. I removed the air filter and squirte a little carb cleaner in the carb and set the can aside. It then coughed and ran for a few seconds. I did it the second time and it started up and ran normally.
In your case, it will depend on its condition when you stored it. If it had fuel in the carb bowl without Stabil, B12 or something, then you might have a bigger challenge than I did. If the battery won't take a charge, replace it and then do like I did. WARNING, DO NOT get the idea to spray a stream of carb cleaner or gas or something in the carb while trying to start. Many people have been burned and even killed doing this. Just squirt a little in there and set the can aside before trying to start it.
If the carb cleaner won't make it run, you might have to take apart the carb and clean out the varnish.
Once it's running, get it warm and drain the oil, preferably overnight since the last drops coming out are the grungiest.
Once it's running and engine oil is changed, just go through it as necessary. Lube everything and change other fluids if they were not changed shortly before storage.
Hope this helps. Keep us posted regarding progress.
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
SELLICK S80 STRAIGHT MAST FORKLIFT (A51242)
SELLICK S80...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
