Cub cadet 1541 serious oil problem
   / Cub cadet 1541 serious oil problem #1
kenpaul
thunder bay ont canada
My. 1541 Cub Cadet is on its second engine is a Kohler m18
First engine seized up at 600 hours
This one started with a rear seal leak so I replaced the seal but seems to be blowing oil when running
Almost like serious pressure
Oil filter is new breather is not plugged just a lot of oil blowing out past the seal
Any thoughts?
   / Cub cadet 1541 serious oil problem #2
If you think the breather is ok about the only idea I have is to pull the head and see what you have. Did it run low on oil when it was leaking?
It may have run a bit low for a very short period low on oil but I caught it pretty quick.i took the breather cover off and blew thru the hose and it seems clear unless I am missing something. It started and runs good just a lot of oil getting flung around via the crankshaft
Should there be a lot if pressure there or not.Is there a crank case vent i am missing
   / Cub cadet 1541 serious oil problem #5
Most small engines have a crank case vent either connected to intake manifold - carburetor area or vented directly to atmosphere. Not familiar with kohler M18 so not sure which system they have.
   / Cub cadet 1541 serious oil problem #6
The M18 has a crankcase vent going into the bottom of the air cleaner. There should be minimal out gassing venting from this crankcase vent.
If there is a lot of bypass/venting from this crankcase vent you may have a bad valves/head gasket or rings issue. Usually if it's rings, it uses/burns oil tho.
   / Cub cadet 1541 serious oil problem #7
Do you have equipment to perform compression test? If yes this should help diagnose if bad cylinder and possibly if valves or rings. Typically if rings shooting a little oil in the spark plug hole and immediately recheck compression will provide higher compression reading. Bad valve compression usually does not change nor would a leaking head gasket typically show compression change.
Thanks I will check the compression that helps give me some direction
Lots of pressue at the breather tube and oil fill pipe when i crank the engine over the engine doesn't use a lot of oil so will check compression
   / Cub cadet 1541 serious oil problem #9
A leak down test would tell you more than a compression test.
Compression test is 60 lbs per each cylinder not sure what it is supposed to be
When it warms up I am thinking I will' pull the heads
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2018 CATERPILLAR 320GC EXCAVATOR (A51242)
2018 CATERPILLAR...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
2022 JOHN DEERE 320G WHEELED SKID STEER (A51242)
2022 JOHN DEERE...
