Cub Cadet 149 hydraulic lift problem
   / Cub Cadet 149 hydraulic lift problem #1
jeff216410
Cub Cadet 149
I have a problem with the hydro lift slowly drifting down on my 149 while it is running. I started noticing the mowing deck getting lower and lower as I am mowing and have to lift it up every now and then. This past year in the snow, after about 1.5 hours of blowing snow the snowthrower would not stay up. I had to keep the lift lever pulled to keep the snowthrower raised otherwise it would just fall to the ground. That tells me the fluid was hot (and thin) from running at max engine speed and power for a long time. Where in the hydraulic system should I look at to fix? It seems like I have an internal fluid leak somewhere.
   / Cub Cadet 149 hydraulic lift problem #2
I'd lay odds that it is the cylinder leaking!
is the cylinder on a 149 rebuildable? I'm assuming it needs new seals inside? Thanks!
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2025 K4525 UNUSED Double Garage Steel Barn (A50860)
2025 K4525 UNUSED...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
UNUSED 120 Pairs Safety Work Gloves (A50860)
UNUSED 120 Pairs...
