Cub Cadet 1440 Hydro problem?
   / Cub Cadet 1440 Hydro problem? #1
coolmac
I bought the CC 1440 2 years ago and changed all fluids/filters.
All was great until yesterday, no forward or reverse after 2 min into the cut. The Briggs engine running great and doesn't load down at all.
I checked hydro driveshaft, linkages, fluid level and hydro relief valve. No leaks. All good. I pushed to the garage, that sucked. What was odd, I could push the tractor with the hydro relief valve engaged or disengaged ? The tractor just makes a light clicking noise when pushing forward.
Did the hydro pump die, relief valve sticking, any other checks?
I trying to determine if its the hydro or rear end.
Replaced the Fram 2844 hydro filter with a CC filter and all is good.
The Fram must of clogged.
Back to mulching leaves. . .
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
SCAN FOR HAULING AND FINANCING INFORMATION (A51243)
SCAN FOR HAULING...
2014 International Pro Star Semi (A50514)
2014 International...
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
