I am looking for suggestions on what could cause this mower to just stop
moving. A friend was mowing with it and it just stopped moving. I know
the problem is definitely in the transmission or the hydro pump. Drive belt
is perfect and tight and fluid level is fine. If I jack it up, and put it in gear,
the wheels will turn a little but as soon as you grab them, they stop.
I was wondering if this sounds like a hydro problem or maybe a sheared pin
in the transmission? Also, I know you aren't supposed to be able to move
these things without disengaging the hydro (dump valve) but on this one,
you can move it with no problem regardless of whether you disengage the
pump or not. Thanks in advance.
