Cub Cadet 125 voltage regulator/solenoid
   / Cub Cadet 125 voltage regulator/solenoid #1
golfgod7
I just purchased a 68 cub cadet 125. The owner said the battery was dead so he jumped it directly to the starter and it fired right up. I purchased a new battery and turned the key with no result. I believe the problem is either the starter solenoid or voltage regulator. How can i properly diagnose these to determine where the issue is? I am also looking for a good source of Cub Cadet parts and manuals. Any ideas you may have is appreciated.
Jim
   / Cub Cadet 125 voltage regulator/solenoid #3
I think there is a black voltage regulator at the front near the grill, and vibrations take their toll on the wires going to it. The prior poster is correct about what to check, but I remember having to fix these wires on a 107 a couple of times. Just a thought. Good luck.
   / Cub Cadet 125 voltage regulator/solenoid #4
If you hear a clicking sound, then it is your starter solenoid.
A tractor will still run on a bad voltage regulator, but as the voltage is not being accurately regulated, it will burn your wiring harness.
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2017 Chevrolet Sonic Premier Sedan (A55853)
2017 Chevrolet...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
2009 MOROOKA MST-2200 VD TRACKED FLATBED DUMPER (A52707)
2009 MOROOKA...
Kubota B2301 (A53317)
2023 New Holland TS6.140 T4B MFWD Tractor (A53485)
2023 New Holland...
