Cub 7260 Clutch Replacement
   / Cub 7260 Clutch Replacement #1
BBSTEIN2
Boston, NY
Cub Cadet 7260
I have a 2000 7260 with 550 hrs. that I bought used with the manual transmission that appears to need a new 2stage clutch. The tractor drives okay in low or mid range but if you put it in high range and let out the clutch it either will barely move or not move at all if on an incline. Also if you depress the clutch pedal and try to engage the PTO it just grinds so it seems the clutches are not functioning properly. I have adjusted the pedal travel according to the manual.
I would appreciate it if anyone has any pointers or has been through this. My brother works on heavy equipment so we are probably going to pull it apart in his shop. I would also appreciate any suggestions for a place to order the parts once we see what we need. Thanks
SCAN FOR HAULING AND FINANCING INFORMATION (A51243)
SCAN FOR HAULING...
KMC KELLEY 3374 PORTABLE PEANUT COMBINE (A51243)
KMC KELLEY 3374...
CASE 1150C CRAWLER DOZER (A51242)
CASE 1150C CRAWLER...
Electric Mobility Scooter (A51694)
Electric Mobility...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
John Deere 1025R Tractor (A50514)
John Deere 1025R...
