Cub 5254 transmission work
   / Cub 5254 transmission work #1
ruggeri5054
Cub 5254
I have a cub 5254 with the dreaded issues... but anything can be fixed... so I am going to d@mn well try. PS, I understand that some of these are not worth the work however I am not at the point where I am going to drop 20k+ on a new one .. please help lol
So what happened? FIRST issue, randomly my PTO went out and appeared that the shaft was jammed and burned up the clutch, the shaft will not turn. What did I do after this? not a **** thing I hardly use it. I only use the loader.. anyways I knew that this would likely cause issues down the road,
fast forward to winter, I was plowing snow and the trans started jerking in forward and backward as if the gears were missing a few teeth. within a few days, completely would not move.
Drained the oil did not really see any metal shavings..
At this point, I assume whatever blew apart in the PTO may have got caught in the gears and blew them apart too.. IDK without tearing it apart.
My main questions are .. 1, anything similar to any of you in the past? and 2, is there any detailed information about the transmission in these...? The service manual is about as useful as a wet paper bag when it talks about the trans..
YES I know these transmissions were chineese junk, but when I split the case, everything that can be replaced will be. Oil seals to gears.
If any one either has parts, or has tore one of these apart before, please give me some input because according to the diagram it looks like a satans playground
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
TRUCKING INFO (A50775)
2019 Allmand Light tower (A49461)
2019 Allmand Light...
